GRASS on 64bit machines
Bernhard Reiter bernhard at uwm.edu
Fri Oct 22 18:02:29 EDT 1999
On Fri, Oct 22, 1999 at 01:12:50PM -0500, Rado Bonk wrote:
> Does anybody has experiences with installing GRASS5beta3 on 64 bit
> ULTRALinux or SOLARIS 7.0.
No, but Bill Hughes run it on GNU/Linux for alpha 64 bit and
I got it to run on DEC Unix for alpha 64 bit.
> I would appreciate list of possible
> difficulties when doing installation.
You should definately get the next anticipated grass5.0beta (4).
If you are willing and able to do some bug fixing on it, Markus
might be able to give you acces to this upcoming version.
Otherwise: The portable vector format doesn't work and
64bit might have difficulties reading other people's grass data files.
	Bernhard
Research Assistant, Geog Dept UM-Milwaukee, USA.    (www.uwm.edu/~bernhard)
Free Software Projects and Consulting 			(www.intevation.de)
Association for a Free Informational Infrastructure              (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19991022/7b2a9e7a/attachment.bin
