GRASS 5 beta4 on DU alpha
Luca Palmeri
lpalmeri at ux1.unipd.it
Tue Oct 26 13:41:20 EDT 1999
To DU 64bit users and developers,
I post in attachment to this mail the errors
and fixes I had to do in order to compile grass5beta4
on Digital Unix alpha.
I had to modify the source code in many places. I do
not actualy know how much of these changes are specific
to the particular system I installed grass on, or to
*my choice* of using cc instead of gcc. Anyhow
I hope these help if somebody runs into troubles in
compiling on a 64bit system
Luca
--> Luca Palmeri - Dip. Proc. Chimici dell'Ingengeria
Universita' di Padova TEL: +390498275527 -------
------------------------- FAX: +390498275528 -------
--> Think holistic @ the end of the 2nd millenium <--
October 26, 1999 - GRASS5.0beta4
What I had to do to compile under Digital Unix (alpha)
Preamble:
a - I do not have root privileges on this system, and
I also have some quota limits. So I cannot install all
the librares I would like to.
b - Grass compiles. Yes the fundamentals modules go without
big problems. But I wanted to go pedanthic up to the src.contrib
that it isn't needed in order to have a fully working system
c - The system I am compiling grass on it is not very up to
date.Digital UNIX V4.0D (Rev. 878). Moreover I am not really
expert of this kind of systems.
d - I have used grass for a while after compilation and seems
working very well.
First of all switch to 64bit mode as suggested by Bill
Hughes, by changing in src/mapdev/diglib/portable.c
#define LNG_SIZ 8 /* on 64bit platforms */
before compile, after doing ./configure
0) Changed "gcc" -> "cc" and "-g" -> "-g3" in src/CMD/head/head
cc likes very much the -g3 optimization with debugging symbols
1) in src/Makefile: Modify "install -d -m 755" with "mkdir -m 755"
DU install seems not to understand -d option
during compile:
2) changed "-lncurses" -> "-lcurses" in src/CMD/head/head. I do not
have SOs ncurses on my system and had some unresolved symbols.
3) exclude by commenting i.points3 from src/CMD/list/GRASS, the
module is broken and cc does not like it
4) same for src/imagery/i.tape.tm3
5) change CM -> CMap in the file src/mapdev/v.digit/defines.h
on the line #define CM CurrentMap, and then in that directory
a substitution:
for a in `ls *.c`; do cat $a | sed "s/CM/CMap/g"> ttt; mv ttt $a;done
This it was necessary due to complaints from the compiler on the
redefinition of the simbel CM already defined in curses.h (see 2).
I guess that with ncurses this shouldn't be necessary.
6) in src/include/geom/basic.h commented the definition of "sbrk" due to the
following compiler error:
cc: Error: /usr/include/unistd.h, line 549: In this declaration, the
type of "sbrk" is not compatible with the type of a previous declaration
of "sbrk" at line number 94 in file src/include/geom/basic.h.
extern void *sbrk __((ssize_t));
7) in the file src/mapdev/v.in.tig.lndmk/globals.h commented the definition of
"dirname" due to the following error:
cc: Error: globals.h, line 77: In this declaration, the type of
"dirname" is not compatible with the type of a previous declaration of
"dirname" at line number 165 in file /usr/include/string.h.
extern char dirname[250]; /* base directory/file name for Tiger files */
8) in file src/raster/r.combine/cmd/local_proto comment the definition of
the prototype for "yywrap()" and then in file
src/raster/r.combine/cmd/gis_lxcl.l comment out the "yywrap()" function.
The error reported by cc is:
cc -g3 -O2 -I/export/venus6b/grass/src/src/include -c gis_lxcl.c
cc: Warning: local_proto.h, line 24: Too many actual parameters in
macro call.
int yywrap(void);
cc: Error: local_proto.h, line 24: Invalid declarator.
int yywrap(void);
cc: Warning: gis_lxcl.l, line 222: Too many actual parameters in
macro call.
int yywrap(void)
cc: Error: gis_lxcl.l, line 222: Invalid declarator.
int yywrap(void)
cc: Error: gis_lxcl.l, line 229: Invalid declarator.
else
9) in file src/raster/r.mapcalc/polish/pol.y also comment out the definition
of yywrap() due to the following error:
cc -g3 -O2 -I/export/venus6b/grass/src/src/include -c y.tab.c
cc: Error: pol.y, line 84: Invalid declarator.
int yywrap()
10) same error in file src/raster/r.weight/inter/local_proto.h and gis_lxcl.l
in that dir. Comment or delete yywrap() call
11) in file src/scripts/contrib/Gmakefile delete the 2nd line
# $(GMAKE) tiger.info
even if that is commented make on DU seems not allowing comented lines
like that in makefile, it complains saying something about files not found.
12) in src/sites/s.surf.rst/tree the compiler says it is not possible to
find stdio.h (???). I commented in Gmakefile the line
EXTRA_CFLAGS=-I ../data
and substituted in src/sites/s.surf.rst/tree/tree.c
#include "dataquad.h" with #include "../data/dataquad.h"
13) In src.contrib/CERL/raster/r.out.mpeg I have the following errors:
(and I just skipped the compilation)
cc -g3 -O2 -I/export/venus6b/grass/src/src/include -c main.c
cc: Error: local_proto.h, line 5: In the declaration of an
unnamed object, the array bounds are incorrectly specified.
int parse_command(int, char *[], char *[][], int *, int *, int *, int *);
14) in src.contrib/CERL/raster/r.water.fea/src/inter/ I have the following
error:
cc -g3 -O2 -I/export/venus6b/grass/src/src/include -c data.c
mv data.o OBJ.alphaev56-dec-osf4.0d/data.o
Make: Don't know how to make -lm. Stop.
Really do not know what it is happening. I just remove $(MATHLIB) from
Gmakefile and add "-lm" to the LDFLAG variable. Works !
in src.contrib/CERL/raster/r.water.fea/src/programs/datafea same
problem, same solution
in src.contrib/CERL/raster/r.water.fea/src/programs/select_basins again.
15) src.contrib/NPS/r.in.utm I have this error and I skip
cc: Error: /usr/lib/libm.il: The 'cc' command cannot be used to compile
PL/I programs
16) in src.contrib/PURDUE/s.voronoi/sw_defs.h incompatible definition
of malloc (???), just delete it.
17) same problem in src.contrib/SCS/misc/m.bsplit/cmd/main.c, same solution
18) src.contrib/SCS/misc/m.lulc.USGS same error as in 14) solution slightly
different: in Gmakefile delete $(MATHLIB) from the line
$(BIN_CONTRIB_INTER)/Mlulc.USGS: $(OBJ) $(GISLIB) $(MATHLIB)
same thing in src.contrib/SCS/misc/m.strip99s
in src.contrib/SCS/raster/r.out.rlc/Gmakefile
and in src.contrib/SCS/raster/r.reclass.scs/inter/
AND THAT'S IT.
