GRASS 5 beta4 on DU alpha
Bernhard Reiter
bernhard at uwm.edu
Tue Oct 26 14:04:45 EDT 1999
On Tue, Oct 26, 1999 at 07:41:20PM +0200, Luca Palmeri wrote:
> I post in attachment to this mail the errors
> and fixes I had to do in order to compile grass5beta4
> on Digital Unix alpha.
Thanks. I couldn't get the source fast enough to start with it.
> I had to modify the source code in many places. I do
> not actualy know how much of these changes are specific
> to the particular system I installed grass on, or to
> *my choice* of using cc instead of gcc. Anyhow
> I hope these help if somebody runs into troubles in
> compiling on a 64bit system
You should create a patch (running diff -u)
on the changed files. This would applying your changes easier.
> before compile, after doing ./configure
> 0) Changed "gcc" -> "cc" and "-g" -> "-g3" in src/CMD/head/head
> cc likes very much the -g3 optimization with debugging symbols
But this is not necessary.
And usually you can give options to configure, like
CC=cc CFLAGS="-std1 -O -g3" ./configure .....
> 2) changed "-lncurses" -> "-lcurses" in src/CMD/head/head. I do not
> have SOs ncurses on my system and had some unresolved symbols.
configure should have taken care of this.
Maybe you have ncurses installed somewhere.
> 7) in the file src/mapdev/v.in.tig.lndmk/globals.h commented the definition of
> "dirname" due to the following error:
> cc: Error: globals.h, line 77: In this declaration, the type of
> "dirname" is not compatible with the type of a previous declaration of
> "dirname" at line number 165 in file /usr/include/string.h.
> extern char dirname[250]; /* base directory/file name for Tiger files */
This dirname can be removed totally. (It is in myt last patch.)
> 11) in file src/scripts/contrib/Gmakefile delete the 2nd line
> # $(GMAKE) tiger.info
> even if that is commented make on DU seems not allowing comented lines
> like that in makefile, it complains saying something about files not found.
I would recommend to install gnumake and bison/flex.
It doesn't take that much space, and really helps.
I will go for the compile soon.
Bernhard
Research Assistant, Geog Dept UM-Milwaukee, USA. (www.uwm.edu/~bernhard)
Free Software Projects and Consulting (www.intevation.de)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19991026/5ebc893f/attachment.bin
