Box Counting Method
DIETER LEHMANN
lehmann at fh-nuertingen.de
Thu Sep 23 09:11:59 EDT 1999
Hi Markus,
I think, that r.le should do the job. But - it is not working for me (I
send a mail to the list some time ago, but received no answer...)
Dieter
From: neteler at geog.uni-hannover.de (Markus Neteler)
Subject: Re: Box Counting Method
To: grass at cecer.army.mil
Date sent: Fri, 17 Sep 99 7:32:36 BST
Send reply to: grass at cecer.army.mil
> > I've written a box counting program for GRASS. It uses bit-flipping
> > techniques which means that it's very quick, but as a result it may
> > only run on little endian machines (e.g. Intel-based machines, which
> > is all I have access to). You can find out more and download the
> > source code by following the links from my signature.
> > Dr. Mark Lake
> > http://www.ucl.ac.uk/archaeology/research/profiles/lake.htm
> Hi Mark, hi all,
> currently I am searching for a GRASS module to calculate
> the fractal dimension of remote sensing images. I think
> the box counting method should be fine for that.
> So I have a few questions (as not being very experienced with fractals
> in GIS yet):
> - I would need a module which accepts grey scale images instead
> of binary images
> - the result should be regionalised: A resulting raster map would show
> the distributed fractal dimension so that you could distinguish
> different types of landscape
> Is that possible with (modified) r.boxcount? Or do I have to write a
> new module?
> Does anybody have experience here?
> Any help is appreciated!
> Markus Neteler
_____________________________________
Dieter Lehmann
State University of applied Sciences
Schelmenwasen 4-8
D-72622 Nuertingen, Germany
Phone: +49 (0) 7022 404 Ext. 192 or Ext. 152
Fax: +49 (0) 7022 404 Ext. 166
