hdf
Alejandro Hinojosa
alhinc at cicese.mx
Mon Sep 27 16:18:25 EDT 1999
Hi Bruce,
Do you know if r.in.hdf will read HDF MAS-50 files? This file
format is used on an hyperspectral sensor called MASTER with
50 bands.
Regards
Alejandro Hinojosa
At 12:44 PM 9/27/99 -0500, you wrote:
>Agustin,
>The module is r.in.hdf and is present in your 4.2 version.
>It's command-line and we use it to import NWS NEXRAD
>data into GRASS. While it's not present in 5.0beta, it
>*should* compile there. It will generate 4.x format files.
>We're working on fp conversions for all 4.x modules, but
>this is a slow process due to our current work loads. LEt
>me know if you need any help with this.
>Bruce
>Bruce Byars
>GRASS Dev. Team
>Baylor University
>Agustin Lobo wrote:
>> Hi!
>> I remember that somebody mentioned
>> a program to import hdf files to grass (r.in.hdf?),
>> but cannot find it. Does anybody have any news on this
>> topic?
>> Thanks
>> Agus
>> Dr. Agustin Lobo
>> Instituto de Ciencias de la Tierra (CSIC)
>> Lluis Sole Sabaris s/n
>> 08028 Barcelona SPAIN
>> tel 34 93409 5410
>> fax 34 93411 0012
>> alobo at ija.csic.es
>> http://pangea.ija.csic.es/alobo
