ps.map questions
Markus Neteler
neteler at geog.uni-hannover.de
Thu Apr 13 15:07:57 EDT 2000
On Thu, Apr 13, 2000 at 07:51:16PM +0100, Markus Neteler wrote:
> On Thu, Apr 13, 2000 at 09:46:07AM -0700, Rich Shepard wrote:
> > On Thu, 13 Apr 2000, Markus Neteler wrote:
> > These are all great! But, I still don't see where one can specify the page
> > size (inches or millimeters). Conceptually, the same printing functions
> > should work on any size available in the printer or plotter.
> Rich,
> you need to create file for ps.select here:
> etc/paint/ps.devices/
> Example (a0 size):
> etc/paint/ps.devices/a0
> Contents:
> ----- cut here--------
> level: 2
> page width: 33.07
> page height: 46.77
> top margin: 0.5
> bottom margin: 0.5
> left margin: 0.25
> right margin: 0.25
> resolution: 300
> That's all. Then use ps.select to select and ps.map
> afterwards.
Just now I have added the standard (european) paper sizes into
GRASS 5/CVS. If compiling ps.map (or using the next binary release)
you get several ps.devices already defined. This makes life more
easy, I hope.
I have added a0, a1, a2, a3, a4 paper sizes.
Source code location (CVS only actually):
src/ps.map/ps.map.old/devices/
src/ps.map/ps.map.new/devices/
Best regards
Markus Neteler
