reprojection of rasters
Markus Neteler
neteler at geog.uni-hannover.de
Fri Apr 21 06:03:56 EDT 2000
On Thu, Apr 20, 2000 at 11:18:42AM -0600, twiens wrote:
> I'm fairly new to GRASS so this may have been discussed earlier on the
> list serv. Sorry if I'm repeating a common question. I can't find any
> obvious methods for reprojecting rasters. What I've done is import the
> raster, convert to a vector and then reproject the vector and finally
> convert the vector back to a raster.
> Is there a more elegant method of doing so? Does this method introduce
you can reproject in different ways:
- i.rectify: using control points on a map reference, linear (affine
transformation), 4 points required in maps corner
- i.rectify2: using control points on a map reference, non-linear
(polynomial transformation). The number of control points required for a
selected order of transformation (represented by n) is
((n + 1) * (n + 2) / 2)
[for a 3rd order transformation you need at least 10 control points)
- r.proj: reprojects using GRASS internal projection software (PROJ4).
No control points needed. Limitation: currently transforms full
locations only. If you just need a map portion, create a new smaller
location first before transforming into new location (with other
projection).
The i.rectify* commands are for satellite images etc., r.proj (v.proj)
for maps.
See the man pages for details:
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/
Kind regards
Markus Neteler
