New problem compiling grass5.0beta7
Markus Neteler
neteler at geog.uni-hannover.de
Mon Apr 24 11:43:49 EDT 2000
Hi Skip,
On Mon, Apr 24, 2000 at 07:40:10AM -0700, Skip wrote:
> /usr/local/grass5.0beta/src/raster/r.binfer
> mkdir OBJ.i686-linux-elf
> make -f OBJ.i686-linux-elf/make.rules
> make[1]: Entering directory `/usr/local/grass5.0beta/src/raster/r.binfer'
> rm -f lex.c gram.c
> yacc binfer.y
> rm -f gram.c
> mv y.tab.c gram.c
> rm -f OBJ.i686-linux-elf/gram.o
> gcc -g -O2 -I/usr/local/grass5.0beta/src/include -c gram.c
> mv gram.o OBJ.i686-linux-elf/gram.o
> lex binfer.l
> make[1]: lex: Command not found
... this is easy: just install the "lex/flex" program. Using
SuSe use "YAST" to install "flex" and "yacc". lex is a requirement
to build GRASS.
Then run again
configure
make install
Hope this helps
Markus
