Repeating colormap in ps.map
Joseph Brian Adams, PhD
brian_adams at jbadams.com
Thu Aug 31 07:01:09 EDT 2000
Thanks for all of your help. I think that it is my raster map that is the
problem. I created it from a vector map, and it had several islands that I set
to the same category as the surrounding area. When I run ps.map on with a
raster map that does not have the islands, it works great! I am going to
recreate the raster map without the islands and try again. Thanks again.
Brian
On Thu, 31 Aug 2000, you wrote:
> > I am using 5.0b7. I suspect that this has something to do with my raster map.
> > It contains several islands within one of the regions. Nevertheless, when I
> > imported it from vector to raster, I set those islands to the same category as
> > the surrounding region. d.legend indicates them correctly, though.
> I tested similar script file on my data and it works OK. I can't test better
> without sample of data.
> In 5.0b7 is old version of ps.map. In 5.0b8 was replaced by ps.map.new
> however no changes were done to colortable except mentioned 'nodata [y|n]' .
> There are also new options for vectors: filled areas, label in legend, ...
> See html man.
> Radim
