MapInfo to GRASS
    Bruce Byars
    Bruce_Byars at baylor.edu
    Tue Feb  8 08:22:48 EST 2000
Roy,
GRASS can import raw ASCII files with no problems, so if you have
a choice, go with ASCII.  Presently, there's no direct way to import
MapInfo binaries directly.
Bruce
Roy Sanderson wrote:
> Dear All
> Apologies if this has been asked before, but is there a simple way of
> converting from MapInfo format into GRASS?  I'm about to be sent some
> MapInfo format files - presumably these can be either ASCII or binary.
> Currently running GRASS 4.2.1 on RH Linux 6.0
> Thanks
> Roy
> Roy Sanderson
> Centre for Land Use and Water Resources Research
> Porter Building
> University of Newcastle
> Newcastle upon Tyne
> NE1 7RU
> United Kingdom
> Tel: +44 191 222 7789
> Fax: +44 191 222 6563
> r.a.sanderson at newcastle.ac.uk
> URL: http://www.cluwrr.ncl.ac.uk
