Compiling nviz2.2
    Kurt Gerber
    kgerber at gmx.ch
    Tue Jan 11 13:59:33 EST 2000
Hi Markus
I have Tcl/Tk 8.0.5 installed. It seems, that Suse 6.3 contains only this new
one and no more the old libraries...
So the problem seems to be more complicated. Should I better download the
binaries?
  On Die, 11 Jan 2000, you wrote:
>Hi Kurt,
>please check (especially as you are using SuSe) if you have
>installed Tcl/TK 8.0.5. Up to SuSe 6.2 the tcl/tk library
>versions have been 7.6 and 4.x, the new versions were called
>tcl_new and tk_new (in YAST install program). I don't know
>if SuSe finally changed to tcl/tk 8.x now for the standard
>installation.
>Check:
> /usr/local/include/tk.h
> /usr/local/include/tcl.h
>Or
> /usr/include/tk.h
> /usr/include/tcl.h
>for the version number.
>It should look like this:
>#define TK_MAJOR_VERSION   8
>#define TK_MINOR_VERSION   0
>#define TK_RELEASE_LEVEL   2
>#define TK_RELEASE_SERIAL  5
>#define TK_VERSION "8.0"
>#define TK_PATCH_LEVEL "8.0.5"
>Cheers
> Markus
>PS: Please aware of include file confusion if you have *both*
>    libraries installed. Then it depends on the path order which
>    tk.h/tcl.h is read first (should be 8.0.5).
>On Mon, Jan 10, 2000 at 08:42:43PM +0100, Kurt Gerber wrote:
>> Hi
>> I compiled Grass 5.0beta5 on Suse 6.3 (kernel 2.2.13). After that I tried to
>> compile Nviz 2.2. It stopped with the following error message:
>> usr/src/grass5.0beta/src/libes/ogsf
>>   make -f OBJ.i686-linux-elf/make.rules
>> make[2]: Entering directory `/usr/src/grass5.0beta/src/libes/ogsf'
>> make[2]: Nothing to be done for `all'.
>> make[2]: Leaving directory `/usr/src/grass5.0beta/src/libes/ogsf'
>> touch nviz_init.c
>> rm -f OBJ.i686-linux-elf/tkAppInit.o
>> gcc -g -O2  -I/usr/src/grass5.0beta/src/libes/ogsf -I/usr/src/grass5.0beta/src/mapdev/Vlib -I/usr/src/grass5.0beta/src/mapdev/diglib -D_NO_PROTO -D__STDC__ -I/usr/include -I/usr/include/GL -I/usr/include/X11 -DSRC_BOOT=\"/usr/local/grass-5.0b/etc/nviz2.2/scripts\" -I /usr/src/grass5.0beta/src/libes/LIB.i686-linux-elf/libgis.a -I/usr/src/grass5.0beta/src/include  -c tkAppInit.c
>> In file included from togl.h:19,
>>                  from tkAppInit.c:8:
>> tkInt.h:42: conflicting types for `Tk_PostscriptInfo'
>> /usr/include/tk.h:109: previous declaration of `Tk_PostscriptInfo'
>> make[1]: *** [OBJ.i686-linux-elf/tkAppInit.o] Error 1
>> make[1]: Leaving directory `/usr/src/grass5.0beta/src.contrib/GMSL/NVIZ2.2/src'
>> make: *** [nvwish] Error 2
>> What this error means? I installed the Tcl/Tk from the SUSE 6.3 distribution.
>> Kurt Gerber
