Troubles compiling Grass 5.0 beta6
jbrowne jbrowne at liu.edu
Wed Jan 19 22:52:48 EST 2000
Juan
     I have had similar problems. I am running SuSE 6.1 with kernel 2.2.7 on a
twin P2 400 SMP machine. the recommended compile seemed to work for me. I ran
configure and then make install. After successfully generating several object
files and doing some linking, the output was:
warning multiple common R(char, long double __restric, long long)
warning multiple common R__cury
warning multiple common V__
unidentified reference to __waddbytes
  I hope that this helps pinpoint the problems so that we can both try again.
                                      Jim
>===== Original Message From "Juan I. Santisteban Navarro"
<juancho at eucmos.sim.ucm.es> =====
>Hi,
>I'm trying to compile Grass 5.0 beta6 and I'm having some troubles.
>First of all, I'm trying to do this in a AMD K6 with Linux RedHat 6.0
>(kernel v 2.2.13)
>My troubles are:
>when I try the new method of compilation
>         ./configure
>         make install
>nothing happens.
>Then I try the classical method (with GISGEN) and it seems to work until
>I receive the message in the module d.3d (and others) that the symbol
>__bsd_signal is undefined in the library libcurses.so.1.0.0 and the
>compilation stops.
>I've tried to use libncurses instead of libcurses, but the I receive the
>message "__waddbytes" is undefined in libncurses.
>I don't know if I need a newer version of these libs or it is something
>related to the code.
>Thanks in advance
>    Santi
>Dr. Juan I. Santisteban Navarro
>Dpto. Estratigrafía/Instituto de Geología Económica
>Fac. Ciencias Geológicas
>Univ. Complutense de Madrid
>28040-Madrid
>SPAIN
>Phone: +34 91 3944785
>Fax: +34 91 3944808
>e-mail: juancho at eucmos.sim.ucm.es
