Beta 5 and its lockfile
jbrowne
jbrowne at liu.edu
Wed Jan 19 23:27:23 EST 2000
Eric,
Thanks, but I tried that, along with running it as root. The lock command
was crashing even when tested in isolation. After getting corrupted HTTP
downloads of binaries and source from Bayor, I used FTP for the binary and had
then this problem. On the chance that it was another download problem, I did
another download from Hannover. Same problem.
If it is working for you, what kernel and glibc versions are you running?
I apparently still have libc5.on the 2.2.7 kernel. Time to update and or
compile.
Thanks again
Jim
>===== Original Message From "Eric G . Miller" <egm2 at jps.net> =====
>Awhile back, I downloaded a binary tarball that unpacked with all kinds
>of funky user/group permissions. I think I got it from baylor. Anyway,
>distribution tarballs shouldn't preserve owner/group (as this one did)
>and may be the source of your problem? Anyway, "chown -R root.staff
>/usr/local/grass5.0beta5" should fix it (substitute appropriate
>ownership for your setup).
>| Eric G. Miller egm2 at jps.net |
>| GnuPG public key: http://www.jps.net/egm2/gpg.asc |
