Help: d.mon x0 fails with "connection refused"
    Gregory Walker
    gwalker at jump.net
    Tue Jun  6 23:41:47 EDT 2000
I am system software developer and was using Unix 20
years ago, but I am a relative newbie to Linux and GRASS.
In fact, I have installed Linux specifically to run GRASS.
I have installed Linux Mandrake 7.0 (kernel 2.2.14-15mdk),
GRASS 5 beta 7, and the spearfish sample data. I can start
GRASS using the spearfish data set but when I enter the
command "d.mon x0" I get the errors:
    GRASS:~ > d.mon x0
    Xlib: connection to ":0.0" refused by server
    Xlib: Client is not authorized to connect to Server
    Graph_Set: can't open :0
It pauses at this point. If I hit ctrl-C, I get the line:
    Problem selecting x0. Will try once more
A second ctrl-C gets me back to the GRASS command prompt.
The same thing happens whether using Gnome or KDE, yet I
have had no problems with other X-applications. I am still
climbing this steep learning curve hand-over-hand, so
any suggestions would be appreciated.
Thank you in advance.
Regards,
Gregory Walker                gwalker at jump.net
