Help: d.mon x0 fails with "connection refused"
Luca Palmeri
lpalmeri at ux1.unipd.it
Wed Jun 7 09:34:04 EDT 2000
Gregory Walker wrote:
> GRASS:~ > d.mon x0
> Xlib: connection to ":0.0" refused by server
> Xlib: Client is not authorized to connect to Server
> Graph_Set: can't open :0
This probably happens because you use grass as a different user from the
user you are logged in with the xserver. The quick solution in a shell
type:
$ xhost +
disables the access control to the xserver.
Luca
Università di Padova - Dip. Processi Chimici dell'Ingegneria
________________ Laboratorio Analisi Sistemi Ambientali
+39.049.827.5528 Via Marzolo, 9 PADOVA (35139), ITALIA
--> http://147.162.77.160
