asking for a lot of grass advice
Bruce Byars
Bruce_Byars at baylor.edu
Sun Mar 5 22:50:00 EST 2000
Hi Rob,
My answers are below your questions. However, if you like, go ahead and
give me a call at the office. We worked with a couple of very similar
projects
to the one I think you are describing. My number is 254-710-6814
Bruce
Bruce Byars
Hydrologist and Senior Research Scientist
CAGSR - GRASS Dev. Team - Baylor University
> I am considering developing a package that will calculate signal
> reception for specific stations using the Longley Rice Irregular
> Terrain Model. I need vector-topo data for the entire country.
> First, do you have to use vector data? Can you use rasters and then
> script up r.mapcalc,
> r.los, and r.binfer to perform your analysis? Raster data may be
> easier to work with from
> your description. Vector topo map for the entire country will be
> BIG. Gigabytes. We already
> have the US DEM's assembled, rectified, and cleaned up and at 90m grid
> resolution the DEM
> is about 2 gigabytes (raster data...I'll calcualte the vector for you
> tomorrow).
> -------------------------------------------------------1. What are
> my options this data? I suppose that I should use the DEM data from
> USGS?
> You can produce vector data from the USGS DEM data without any problem
> using the
> r.poly tool.
> ----------------------------------------------------------------------------------- 2.
> Are there C or Perl libraries for working with DEM's? Specifically,
> to use Longly Rice, I have to resample the vector data to generate an
> elevation profile between two arbitrary points from the vector-topo
> data. Any ideas on that either?
> Personally, I think you will be better off cutting raster transects.
> Tools are already in GRASS
> to do this.
> 3. When I am done I my data will be <long>,< lat>,<reception index>;
> which I plan on treating as a height field. What Grass tools can I
> use to create an image from height field data. You can create a raster
> "elevation" map of your surface with no problem. To create
> nice visualizations, use NVIZ or possibly d.3d
> 4. Also, are there any books out there to jumpstart someone who knows
> things like MapInfo, and Linux, but not Grass??
> We have a brand new tutorial that will be ready this week.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20000305/e43e6135/attachment.html
