Fw: Makefile help
David Armstrong
david.armstrong at dtn.ntl.com
Tue Mar 7 04:08:29 EST 2000
thanks eric ,
it did not seem to help here is a dump of text when doing a make
with no modifications to makfile just a grass ./configure makes it !.
[root at localhost grass5.0beta]# make
if [ ! -d /usr/local/grass-5.0b ]; then mkdir /usr/local/grass-5.0b ; fi
if [ ! -d src/CMD/next_step ]; then mkdir src/CMD/next_step ; fi
/root/.bashrc UNIX_BIN=/usr/local/bin SRC=`pwd`
GISBASE=/usr/local/grass-5.0b MACHINENAME=`uname -n` /bin/sh sr
c/CMD/generic/CREATE_GMAKE.sh
make: *** [pre-install] Error 1
With ENV =
i do not even get this far it croakes on isa64.sh or something
iam i reading this correct in that 'pwd' and 'uname-n' is not being set in
the above line etc
hence the error !.
dave
Linux Mandrake 7 OS
----- Original Message -----
To: "David Armstrong" <david.armstrong at dtn.ntl.com>
Sent: Tuesday, March 07, 2000 2:35 AM
Subject: Re: Fw: Makefile help
> On Mon, Mar 06, 2000 at 04:23:29PM -0000, David Armstrong wrote:
> > Eric,
> > Could you please find time to assist me in altering the makefile or
> > whatever else is needed please as per Pavol message , and attach to
> > email for me This may work regards
> Well, I haven't had to do this, but apparently Mandrake doesn't ship
> with the 'env' command? Anyway, in the top level directory for the GRASS
> sources, open the file "Makefile" in your favorite text editor. You'll
> see a line not to far from the top that maybe says:
> ENV = env
> change that to:
> ENV =
> Then try to compile. You might find out if you do indeed have the 'env'
> command by trying to execute it at the command line. You'll either get a
> long listing of all sorts of environment variables, or you'll get "env :
> Command not found". If you do have it, then this little edit is
> probably won't solve your problem (but try anyway).
> Let me know...
> | Eric G. Miller egm2 at jps.net |
> | GnuPG public key: http://www.jps.net/egm2/gpg.asc |
