v.in.arc: error reading file
    D D Gray
    ddgray at armadce.demon.co.uk
    Wed Mar  8 19:08:09 EST 2000
Markus Neteler wrote:
> Hi David,
> this might be related to G_strip commands used there.
> Please try if you change G_strip to G_squeeze.
> Reason could the the changes from gets to fgets
> and related stuff.
> Hope this helps (if you get it, please send me
> the diffs for the CVS).
>   Markus Neteler
> > I've tried both GRASS4.2.1 and GRASS5beta6, also with
> > an optional 'END' line on each file in all combinations.
> > D Gray
Hi
Actually I must have missed a combination. It _was_ because of
the .lab file not having an END statement. I thimk perhaps I
forgot an EOL, and that's why it didn't pick this up.
Otherwise the build with 'G_squeeze' is working fine.
David.
