Compiling Grass 5.0 beta (final) on IRIX6.5
Eric Mitchell
emitchell at altaira.com
Wed Mar 8 22:34:16 EST 2000
Ok, I finally managed to start this thing compiling
under IRIX6.5 using the native cc compiler, and I ran
into a few minor snags. Nothing terminal, just some
gcc specific extensions and a few casting abiguities.
The diff outputs are included below. I'm not 100%
certain about some of the changes, but this at least
compiled and let me get on about my business.
That is, until I got to
src.contrib/CERL/raster/r.rational.regression,
which looks like its Not Quite Ready for Ansi.
At that point, the compilation dies a horrible
flaming death. the errors are included after the
diffs, below.
General comments:
1) The __attribute__ ((__noreturn__)) feature is
gnu specific, and probably won't work on any other
compilers. A check should be added to configure,
and either "#ifdef __GNUC_MINOR__" (as below), or
do a "#define __attribute__(x)" where unsupported.
2) The configure script should see which *roff is
installed on the machine. An "NROFF = @nroff@"
can be thrown in the top level makefile, and man
page processing should be done using "$(NROFF)"
3) The compiler did generate a large number of
additional warnings, and I have the compilation
log in its entirety for anyone who may be
interested that kind of thing.
emitchell at orion [/opt/grass/grass5.0beta/src/include] - 3 > diff -u gisdefs.h.orig gisdefs.h
--- gisdefs.h.orig Wed Dec 29 10:10:23 1999
+++ gisdefs.h Wed Mar 8 20:25:41 2000
@@ -275,7 +275,11 @@
int G__create_alt_env(void);
int G__switch_env(void);
/* error.c */
+#ifdef __GNUC_MINOR__
int G_fatal_error(char *,...) __attribute__ ((__noreturn__));
+#else
+int G_fatal_error(char *,...);
+#endif
int G_warning(char *,...);
int G_suppress_warnings(int);
int G_sleep_on_error(int);
emitchell at orion [/opt/grass/grass5.0beta/src/display/devices/lib] - 22 > diff -u SWITCHER.c.orig
SWITCHER.c
--- SWITCHER.c.orig Wed Mar 8 20:32:29 2000
+++ SWITCHER.c Wed Mar 8 20:32:52 2000
@@ -556,7 +556,7 @@
xarray = (int *) xalloc (xarray, &n_xarray, x, sizeof (*xarray));
REC (xarray, x * sizeof (*xarray)) ;
if (index !=0) index = 1 ;
- Raster_int(x, y, xarray, index, 1) ;
+ Raster_int(x, y, (unsigned int *) xarray, index, 1) ;
break ;
case RGB_RASTER:
REC (&x, sizeof x) ;
@@ -896,10 +896,13 @@
static int rec(void *buf,int n)
+ char *cbuf = buf;
int stat;
- while (n-- > 0)
- if ((stat=get1(((char* )buf)++)) != 0)
+ while (n-- > 0) {
+ if ((stat=get1(cbuf++)) != 0)
return stat; /* EOF or COMMAND_ESC */
return 0;
emitchell at orion [/opt/grass/grass5.0beta/src/display/devices/lib] - 32 > diff -u font.c.orig
font.c
--- font.c.orig Wed Mar 8 20:36:33 2000
+++ font.c Wed Mar 8 20:37:22 2000
@@ -115,8 +115,9 @@
static int X_copy (int *a,char *b, int n)
+ char *ca = a;
while (n-- > 0)
- (char)*a++ = *b++;
+ *ca++ = *b++;
return 0;
emitchell at orion [/opt/grass/grass5.0beta/src/display/d.rast.edit] - 39 > diff -u edit.h.orig
edit.h
--- edit.h.orig Wed Mar 8 20:44:20 2000
+++ edit.h Wed Mar 8 20:45:02 2000
@@ -62,7 +62,11 @@
/* main.c */
int do_edit(int, int, double);
int error(int, char [128]);
int ext(void) __attribute__ ((__noreturn__));
+#else
+int ext(void);
+#endif
/* menu.c */
int main_menu(void);
int option_menu(void);
emitchell at orion [/opt/grass/grass5.0beta/src/include] - 46 > diff -u config.h.gen config.h
--- config.h.gen Wed Mar 8 20:52:33 2000
+++ config.h Wed Mar 8 20:52:40 2000
@@ -62,7 +62,7 @@
/* #undef uid_t */
/* define curses.h WINDOW structure component */
-#define CURSES_MAXY NONE
+#define CURSES_MAXY _maxy
/* define if ftime() exists */
#define HAVE_FTIME 1
emitchell at orion [/opt/grass/grass5.0beta/src/general/g.setproj] - 53 > diff -u
local_proto.h.orig local_proto.h
--- local_proto.h.orig Wed Mar 8 20:55:15 2000
+++ local_proto.h Wed Mar 8 20:55:38 2000
@@ -25,7 +25,12 @@
int ask_fips(FILE *, int *, int *, int *);
/* main.c */
int min1(int, int);
int leave(int) __attribute__ ((__noreturn__));
+#else
+int leave(int);
+#endif
/* table.c */
int init_table(void);
int get_proj_index(char *);
emitchell at orion [/opt/grass/grass5.0beta/src/general/g.version] - 74 > diff -u main.c.orig
main.c
--- main.c.orig Wed Mar 8 21:03:40 2000
+++ main.c Wed Mar 8 21:04:18 2000
@@ -1,9 +1,11 @@
#include <stdio.h>
+#define QUOTE(x) #x
int main(int argc, char *argv[])
fprintf (stdout, "GRASS %s (%s) %s\n",
- VERSION_NUMBER, VERSION_DATE, VERSION_UPDATE_PKG );
+ QUOTE(VERSION_NUMBER), QUOTE(VERSION_DATE), QUOTE(VERSION_UPDATE_PKG) );
fprintf (stdout, "\n");
fprintf (stdout, "Copyright and License Statement\n");
emitchell at orion [/opt/grass/grass5.0beta/src/general/g.version] - 75 > diff -u Gmakefile.orig
Gmakefile
--- Gmakefile.orig Wed Mar 8 21:00:20 2000
+++ Gmakefile Wed Mar 8 21:05:23 2000
@@ -1,5 +1,5 @@
PGM=g.version
-EXTRA_CFLAGS=-DVERSION_NUMBER="\"$(VERSION_NUMBER)\"" -DVERSION_DATE="\"$(VERSION_DATE)\""
-DVERSION_UPDATE_PKG="\"$(VERSION_UPDATE_PKG)\""
+EXTRA_CFLAGS=-DVERSION_NUMBER="$(VERSION_NUMBER)" -DVERSION_DATE="$(VERSION_DATE)"
-DVERSION_UPDATE_PKG="$(VERSION_UPDATE_PKG)"
$(BIN_MAIN_INTER)/$(PGM): main.o
$(CC) $(LDFLAGS) $(MATHLIB) $(XDRLIB) -o $@ main.o
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.class] - 81 > diff -u local_proto.h.orig
local_proto.h
--- local_proto.h.orig Wed Mar 8 21:09:14 2000
+++ local_proto.h Wed Mar 8 21:09:56 2000
@@ -97,7 +97,11 @@
int nstd225(void);
int nstd250(void);
/* main.c */
void quit(void) __attribute__ ((__noreturn__));
+#else
+void quit(void);
+#endif
int error(char *, int);
/* mouse.c */
int Mouse_pointer(int *, int *, int *);
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.colors] - 87 > diff -u main.c.orig main.c
--- main.c.orig Wed Mar 8 21:12:45 2000
+++ main.c Wed Mar 8 21:13:06 2000
@@ -5,7 +5,11 @@
#include "globals.h"
#include "local_proto.h"
static void quit (int) __attribute__ ((__noreturn__));
+#else
+static void quit (int);
+#endif
static int error(char *,int);
int main (int argc, char *argv[])
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.in.erdas] - 92 > diff -u main.c.orig
main.c
--- main.c.orig Wed Mar 8 21:15:33 2000
+++ main.c Wed Mar 8 21:16:03 2000
@@ -545,7 +545,7 @@
if (!(swapflag->answer || autoswapflag->answer))
ActuallySwap = 0;
- if ((erdashd.pack == 256 ) || (erdashd.pack == 512 )) // 1 or 2 byte-swapped
+ if ((erdashd.pack == 256 ) || (erdashd.pack == 512 )) /* 1 or 2 byte-swapped */
ActuallySwap = 1 ;
if (erdashd.pack == 0)
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.ortho.photo/photo.2image] - 97 > diff -u
globals.h.orig globals.h
--- globals.h.orig Wed Mar 8 21:18:21 2000
+++ globals.h Wed Mar 8 21:19:17 2000
@@ -144,7 +144,11 @@
int Menu_msg(char *);
int Start_mouse_in_menu(void);
/* main.c */
int quit(int) __attribute__ ((__noreturn__));
+#else
+int quit(int);
+#endif
/* mark.c */
int mark(int, int, int);
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.ortho.photo/photo.2target] - 103 > diff
-u local_proto.h.orig local_proto.h
--- local_proto.h.orig Wed Mar 8 21:20:52 2000
+++ local_proto.h Wed Mar 8 21:21:56 2000
@@ -69,7 +69,11 @@
/* main.c */
+#else
+int quit(int);
+#endif
/* mark.c */
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.points] - 109 > diff -u main.c.orig
main.c
--- main.c.orig Wed Mar 8 21:24:44 2000
+++ main.c Wed Mar 8 21:25:07 2000
@@ -6,7 +6,11 @@
#include "raster.h"
int quit (int) __attribute__ ((__noreturn__));
+#else
+int quit (int);
+#endif
int error (char *, int);
emitchell at orion [/opt/grass/grass5.0beta/src/imagery/i.vpoints] - 114 > diff -u globals.h.orig
globals.h
--- globals.h.orig Wed Mar 8 21:28:17 2000
+++ globals.h Wed Mar 8 21:28:31 2000
@@ -155,7 +155,11 @@
/* main.c */
int main(int, char *[]);
+#else
+int quit(int);
+#endif
/* mark.c */
emitchell at orion [/opt/grass/grass5.0beta/src/libes/geom/basic] - 119 > diff -u malloc.c.orig
malloc.c
--- malloc.c.orig Wed Mar 8 21:33:39 2000
+++ malloc.c Wed Mar 8 21:34:20 2000
@@ -8,6 +8,10 @@
#include <sys/types.h>
#endif
+#ifdef sgi
+#include <malloc.h> /* we need the M_DEBUG macro below */
+#endif
#define REPORT_THRESHOLD 1000000
emitchell at orion [/opt/grass/grass5.0beta/src/mapdev/v.geom/cmd] - 124 > diff -u Gmakefile.orig
Gmakefile
--- Gmakefile.orig Wed Mar 8 21:43:17 2000
+++ Gmakefile Wed Mar 8 21:43:51 2000
@@ -5,6 +5,10 @@
LIBES = $(VECTLIB) $(DIG_ATTLIB) $(GISLIB) $(TRIANGLIB)
+ifeq ($(shell uname),IRIX64)
+LIBES += -lmalloc
+endif
SOURCES = \
main.c
emitchell at orion [/opt/grass/grass5.0beta/src/paint/Interface/driverlib] - 129 > diff -u
interface.c.orig interface.c
--- interface.c.orig Wed Mar 8 21:48:06 2000
+++ interface.c Wed Mar 8 21:48:59 2000
@@ -363,16 +363,17 @@
static int rec (void *buf,int n)
int i;
+ char *cbuf = buf;
while (n > 0)
- i = read (0, buf, n);
+ i = read (0, cbuf, n);
if (i == 0)
paint_error ("unexpected EOF");
if (i < 0)
paint_error ("read error");
- (char *)buf += i;
+ cbuf += i;
n -= i;
emitchell at orion [/opt/grass/grass5.0beta/src/paint/Programs/p.map.new/cmd] - 134 > diff -u
scale.c.orig scale.c
--- scale.c.orig Wed Mar 8 21:51:53 2000
+++ scale.c Wed Mar 8 21:52:22 2000
@@ -24,7 +24,11 @@
#define MILES_TO_INCHES ((double)5280*12)
static double do_scale (struct Cell_head *, int, int, char *);
static int OOPS (void) __attribute__ ((__noreturn__));
+#else
+static int OOPS (void);
+#endif
int scale (struct Cell_head *window, int panel, int margin, char *text)
emitchell at orion [/opt/grass/grass5.0beta/src/ps.map/ps.map/cmd] - 139 > diff -u scale.c.orig
scale.c
--- scale.c.orig Wed Mar 8 21:53:48 2000
+++ scale.c Wed Mar 8 21:54:28 2000
@@ -13,7 +13,11 @@
#define PWIDTH (PS.page_width-PS.left_marg-PS.right_marg)
static double do_scale(char *);
static int OOPS() __attribute__ ((__noreturn__));
+#else
+static int OOPS();
+#endif
double scale(char *text)
emitchell at orion [/opt/grass/grass5.0beta/src/raster/r.mapcalc/mapcalc] - 144 > diff -u
maps.c.orig maps.c
--- maps.c.orig Wed Mar 8 21:58:30 2000
+++ maps.c Wed Mar 8 22:00:44 2000
@@ -332,8 +332,9 @@
SETNULL_D(values);
values++;
+ values = vbuf;
btree_update (btree, (char *)&key, sizeof(key),
- (char *)values = vbuf, sizeof(vbuf));
+ values, sizeof(vbuf));
/* and finally lookup the translated value */
emitchell at orion [/opt/grass/grass5.0beta/src/raster/r.statistics/man] - 153 > diff -u
Gmakefile.orig Gmakefile
--- Gmakefile.orig Wed Mar 8 22:05:22 2000
+++ Gmakefile Wed Mar 8 22:05:58 2000
@@ -2,8 +2,14 @@
MDIR=$(SRC)/../man/man$(MSEC)
MUTL=$(SRC)/../man/utilities
+NROFF = groff
+else
+NROFF=nroff
+endif
man:
-cp r.statistics.man $(MDIR)/r.statistics
- nroff $(MUTL)/man.version $(MDIR)/.class-header \
+ $(NROFF) $(MUTL)/man.version $(MDIR)/.class-header \
$(MUTL)/man.header r.statistics.man $(MDIR)/.class-notice \
> $(GISBASE)/man/$(MSEC)/r.statistics
emitchell at orion [/opt/grass/grass5.0beta/src/scripts/contrib/s.in.grid] - 158 > diff -u
--- Gmakefile.orig Wed Mar 8 22:09:42 2000
+++ Gmakefile Wed Mar 8 22:09:54 2000
@@ -16,6 +16,11 @@
+NROFF = groff
+else
+NROFF=nroff
+endif
all : $(PROG) man
@@ -26,7 +31,7 @@
man:
-cp $(PGM).man $(MDIR)/$(PGM)
$(MUTL)/man.header $(PGM).man $(MDIR)/.class-notice \
> $(GISBASE)/man/$(MSEC)/$(PGM)
emitchell at orion [/opt/grass/grass5.0beta/src/sites/s.kcv] - 165 > diff -u Gmakefile.orig
Gmakefile
--- Gmakefile.orig Wed Mar 8 22:16:35 2000
+++ Gmakefile Wed Mar 8 22:16:51 2000
@@ -11,6 +11,12 @@
histo.o \
utils.o
+NROFF = groff
+else
+NROFF=nroff
+endif
all: s.kcv man
s.kcv: $(BIN_CONTRIB_CMD)/s.kcv
@@ -20,7 +26,7 @@
man:
-cp s.kcv.man $(MDIR)/s.kcv
$(MUTL)/man.header s.kcv.man $(MDIR)/.class-notice \
> $(GISBASE)/man/$(MSEC)/s.kcv
lint:
emitchell at orion [/opt/grass/grass5.0beta/src.contrib/CERL/raster/r.out.mpeg] - 170 > diff -u
--- local_proto.h.orig Wed Mar 8 22:21:37 2000
+++ local_proto.h Wed Mar 8 22:22:00 2000
@@ -2,7 +2,6 @@
int load_files(void);
int use_r_out(void);
char **gee_wildfiles(char *, char *, int *);
-int parse_command(int, char *[], char *[][], int *, int *, int *, int *);
/* write.c */
int write_ycc(char *, char *, char *, int, int, int *, int *, char *);
int write_ppm(char *, char *, char *, int, int, int *, int *, char *);
emitchell at orion [/opt/grass/grass5.0beta/src.contrib/CERL/raster/r.out.mpeg] - 172 > diff -u
main.c.orig main.c
--- main.c.orig Wed Mar 8 22:22:22 2000
+++ main.c Wed Mar 8 22:23:10 2000
@@ -38,6 +38,9 @@
#define USE_PPM
+int parse_command(int, char *[], char *[MAXVIEWS][MAXIMAGES],
+ int *, int *, int *, int *);
int nrows, ncols, numviews, quality, quiet=0;
char *vfiles[MAXVIEWS][MAXIMAGES];
char outfile[BUFSIZ];
/opt/grass/grass5.0beta/src.contrib/CERL/raster/r.rational.regression
make -f OBJ.mips-sgi-irix6.5/make.rules
make[1]: Entering directory `/opt/grass/grass5.0beta/src.contrib/CERL/raster/r.rational.regression'
rm -f OBJ.mips-sgi-irix6.5/xformation.o
cc -g -I/opt/grass/grass5.0beta/src/include -c xformation.c
"xformation.c", line 49: warning(1116): non-void function "normalization_x1"
(declared at line 6) should return a value
"xformation.c", line 101: warning(1116): non-void function "normalization_x2"
(declared at line 53) should return a value
"xformation.c", line 153: warning(1116): non-void function "ndvi" (declared at
line 104) should return a value
"xformation.c", line 209: warning(1116): non-void function "ndvi_intensity"
(declared at line 156) should return a value
"xformation.c", line 264: warning(1116): non-void function "ndvi_reflectance"
(declared at line 211) should return a value
"xformation.c", line 323: warning(1116): non-void function "rvi" (declared at
line 268) should return a value
"xformation.c", line 578: warning(1116): non-void function
"nonlinear_linearization" (declared at line 327) should return a
value
"xformation.c", line 817: warning(1116): non-void function
"nonlinear_linearization_NDVI" (declared at line 581) should return
a value
"xformation.c", line 969: warning(1551): variable "standard_residual_old" is
used before its value is set
standard_residual, standard_residual_old);
"xformation.c", line 972: warning(1116): non-void function "relaxation"
(declared at line 820) should return a value
"xformation.c", line 984: error(1153): declaration is incompatible with
previous "vector" (declared at line 12)
y2=vector(ndata);
"xformation.c", line 984: error(1515): a value of type "int" cannot be
assigned to an entity of type "double *"
y2=vector(ndata);
"xformation.c", line 985: error(1515): a value of type "int" cannot be
epsilon=vector(ndata);
"xformation.c", line 1054: warning(1116): non-void function "prediction_linear"
(declared at line 975) should return a value
"xformation.c", line 1264: warning(1116): non-void function
"prediction_linear_other" (declared at line 1058) should return a
value
"xformation.c", line 1280: error(1515): a value of type "int" cannot be
y2=vector(ndata);
"xformation.c", line 1281: error(1515): a value of type "int" cannot be
"xformation.c", line 1351: warning(1116): non-void function
"prediction_nonlinear" (declared at line 1270) should return a value
"xformation.c", line 1527: warning(1116): non-void function
"prediction_nonlinear_other" (declared at line 1358) should return a
value
5 errors detected in the compilation of "xformation.c".
make[1]: *** [OBJ.mips-sgi-irix6.5/xformation.o] Error 2
make[1]: Target `/opt/grass/etc/bin/contrib/cmd/r.rational.regression' not remade because of errors.
make[1]: Leaving directory `/opt/grass/grass5.0beta/src.contrib/CERL/raster/r.rational.regression'
GISGEN failure at STEP: src.contrib/CERL/raster/r.rational.regression
make: *** [do-install] Error 1
make: Target `install' not remade because of errors.
-- ebm
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
