[GRASSLIST:1097] Re: Mac OS X build
Markus Neteler
neteler at geog.uni-hannover.de
Thu Nov 9 05:38:08 EST 2000
Hi Jeshua,
GRASS 5 MacOS binaries are "wanted". If you will build them,
we might be able to assist in case of problems.
I suggest me switch to grass5 developers list:
http://www.geog.uni-hannover.de/grass/grassdevel.html
or to personal communication for details. I highly recommend
you use the CVS-version for compiling as platform independence
has been improved again:
http://www.geog.uni-hannover.de/grass/grasscvs.html
The reprojection of your data should be possible with
GRASS (r.proj, v.proj, s.proj).
Kind regards
Markus Neteler
GRASS Development Team
On Wed, Nov 08, 2000 at 02:37:56PM -0800, Jeshua Lacock wrote:
> Hello all,
> First, I would like to state that I have never used Grass before,
> however I am going to attempt to compile the Grass 5 beta 8 in the
> MacOS X environment. MacOS X is based on BSD so I assume that I
> should be able to build binaries.
> Are there any gotchas, tips, needed libraries or suggestions anyone
> might be able to offer before I embark on this adventure?? Or better
> yet, has anyone attempted to compile binaries for MacOS X yet???
> By the way, I plan on using Grass ( hopefully ) to re-project USGS
> DRG's from a custom Albers projection to a standard UTM projection
> and update the .tfw world file with the correct UTM coordinates.
> I greatly appreciate any advice!
> Thanks,
> Jeshua Lacock
> Cartographer/Owner
> http://SierraMaps.com
> Telephone: (760) 935-4481
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
