[GRASSLIST:1106] Re: compiling cvs source tree
    mlennert at club.worldonline.be
    Sun Nov 12 13:48:23 EST 2000
I updated with the -dP option, but nothing changes.
Here's the output of make pre-install:
test -d /usr/local/grass-5.0b || mkdir -p -m 755 /usr/local/grass-5.0b
test -d src/CMD/next_step || mkdir -p src/CMD/next_step
UNIX_BIN=/usr/local/bin SRC=`pwd` MAKE=make NAME_VER=`cat src/CMD/VERSION |
head -1 | sed 's/\..*//'` GISBASE=/usr/local/grass-5.0b MACHINENAME=`uname -n`
/bin/sh src/CMD/generic/CREATE_GMAKE.sh
cat: src/CMD/generic/../head/head.: No such file or directory
/bin/sh `pwd`/src/CMD/generic/is64bit.sh
cat: /usr/local/grass/src/CMD/generic/../head/head.: No such file or directory
/usr/local/grass/src/CMD/generic/is64bit.sh: 64test.c: command not found
/usr/local/grass/src/CMD/generic/is64bit.sh: ./a: No such file or directory
/usr/local/grass/src/CMD/generic/is64bit.sh: [: : integer expression expected
echo "Now proceed with make install"
No 'head.$ARCH' file is created, and it looks for a 'head.' file that
obviously doesn't exist either. There is a 'head' file in the src/CMD/head
directory (next to the 'head.in' file) with 'i586-linux-elf' as entry for the
ARCH variable.
Moritz
P.S. Markus : Entschuldige die Probleme mit meinem Mailprogramm. Ich bin
gerade auf exmh umgestiegen und habe noch einige Konfigurationsprobleme.
> HI Moritz,
> it must be a local problem, as many people can compile it. But: we will fix
> it.
> So: Did you update with "-dP" option?
> cvs update -dP
> Then you get news directories also, if there.
> P is removing empty directories.
> Ah! Yes, the configure is generating head from
> head.i. Then, if you say
> make pre-install
> you get the head.$ARCH file.
> Could you please try that?
> Then make install should do the job.
> Yours
>  Markus
> On Sun, Nov 12, 2000 at 12:45:53AM +0100, Moritz Lennert wrote:
> > Even when running ./configure again I get the same problem. I attached the
> > config.log file in which there is an error message which might be linked to
> > the problem. In the src/CMD/head directory I get a 'head' file and a 'head.in'
> > file.
> > I'm using Debian/Linux (Potato).
> > > Hi Moritz,
> > > On Sat, Nov 11, 2000 at 06:27:50PM +0100, mlennert at club.worldonline.be wrote:
> > > > Hello,
> > > > I have trouble compiling the cvs source tree. I get the following error
> > > > message after typing 'make install':
> > > ... here is the problem.       ^^^^^
> > > Recently we have updated the Makefile system to generate platform
> > > specific file. Means: Formerly one head.file was generated.
> > > Now you get a head file name depending on the computer platform
> > > e.g. src/CMD/head/head.i686-pc-linux-gnu
> > > After you have run
> > > cvs update -dP
> > > I guess you did not run
> > > configure
> > > again. If you do, the problem should be fixed as the new head-file
> > > will be generated. Sorry for this inconvenience, but now you
> > > can compile GRASS in a network of different platform types from
> > > the same source code tree.
> > > In case of "configure" does not fix your problem, please let
> > > me know.
> > > Kind regards
> > >  Markus
> Content-Description: config.log
> > This file contains any messages produced by compilers while
> > running configure, to aid debugging if configure makes a mistake.
> > configure:571: checking host system type
> > configure:594: checking for gcc
> > configure:707: checking whether the C compiler (gcc  ) works
> > configure:723: gcc -o conftest    conftest.c  1>&5
> > configure:749: checking whether the C compiler (gcc  ) is a cross-compiler
> > configure:754: checking whether we are using GNU C
> > configure:782: checking whether gcc accepts -g
> > configure:815: checking whether ld -s works
> > configure:827: gcc -o conftest -g -O2  -s conftest.c  1>&5
> > configure:852: checking for a BSD compatible install
> > configure:907: checking for flex
> > configure:941: checking for yywrap in -lfl
> > configure:985: checking for ranlib
> > configure:1017: checking for env
> > configure:1051: checking for f77
> > configure:1081: checking how to run the C preprocessor
> > configure:1165: checking for X
> > configure:1479: checking for dnet_ntoa in -ldnet
> > configure:1520: checking for dnet_ntoa in -ldnet_stub
> > configure:1568: checking for gethostbyname
> > configure:1666: checking for connect
> > configure:1758: checking for remove
> > configure:1850: checking for shmat
> > configure:1951: checking for IceConnectionNumber in -lICE
> > configure:1995: checking for ANSI C header files
> > configure:2102: checking for curses.h
> > configure:2102: checking for limits.h
> > configure:2102: checking for termio.h
> > configure:2102: checking for termios.h
> > configure:2102: checking for unistd.h
> > configure:2102: checking for values.h
> > configure:2142: checking for sys/ioctl.h
> > configure:2142: checking for sys/mtio.h
> > configure:2142: checking for sys/resource.h
> > configure:2142: checking for sys/time.h
> > configure:2182: checking for sys/timeb.h
> > configure:2182: checking for sys/types.h
> > configure:2182: checking for sys/utsname.h
> > configure:2219: checking whether time.h and sys/time.h may both be included
> > configure:2254: checking for off_t
> > configure:2287: checking for uid_t in sys/types.h
> > configure:2322: checking curses.h WINDOW structure component
> > configure:2335: gcc -c -g -O2  conftest.c 1>&5
> > configure: In function `t':
> > configure:2331: structure has no member named `maxy'
> > configure: failed program was:
> > #line 2325 "configure"
> > #include "confdefs.h"
> >   #include <curses.h>
> >   WINDOW w;
> > int main() {
> > void t () { w.maxy = 0; }
> > ; return 0; }
> > configure:2354: gcc -c -g -O2  conftest.c 1>&5
> > configure:2372: checking for ftime
> > configure:2372: checking for gethostname
> > configure:2372: checking for gettimeofday
> > configure:2372: checking for lseek
> > configure:2372: checking for nice
> > configure:2372: checking for time
> > configure:2372: checking for uname
> > configure:2427: checking for seteuid
> > configure:2427: checking for setpriority
> > configure:2427: checking for setreuid
> > configure:2427: checking for setruid
> > configure:2480: checking whether setpgrp takes no argument
> > configure:2535: checking for initscr in -lncurses
> > configure:2577: checking for initscr in -lcurses
> > configure:2595: checking for gtty in -lcompat
> > configure:2640: checking for tgetent in -ltermlib
> > configure:2685: checking for xdr_int in -lsun
> > configure:2727: checking for xdr_int in -lnsl
> > configure:2622: checking for gtty in -lcompat
> > configure:2667: checking for tgetent in -ltermlib
> > configure:2712: checking for xdr_int in -lsun
> > configure:2754: checking for xdr_int in -lnsl
> Dipl.-Geogr. Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
