[GRASSLIST:1112] (no subject)
mlennert at club.worldonline.be
Mon Nov 13 06:36:55 EST 2000
'make distclean' doesn't seem to clean the cache. So I tried 'make veryclean'
which does seem to clean the cache, but the problem is still the same...
> mlennert at club.worldonline.be wrote:
> > First of all sorry, if my mails cause problems at the grasslist server. I've
> > been having trouble configuring my mail system correctly, but I think (hope)
> > I'm getting there...
> > I'm sending you the results that I get on my work computer. It's the same
> > system (Debian Potato) and the same CVS-source, so it should be identical (it
> > gives me the same error message at least ;-) )
> > Tell me what kind of guest access you need and I'll send you the address.
> > ./configure:
> > loading cache ./config.cache
> > checking host system type... i686-linux-elf
> > checking for gcc... (cached) gcc
> > checking whether the C compiler (gcc ) works... yes
> > checking whether the C compiler (gcc ) is a cross-compiler... no
> > checking whether we are using GNU C... (cached) yes
> > checking whether gcc accepts -g... (cached) yes
> > ls -la src/CMD/head/ :
> > total 28
> > drwxr-sr-x 4 mlennert privileg 4096 Nov 13 11:46 .
> > drwxr-sr-x 9 mlennert privileg 4096 Nov 13 11:42 ..
> > drwxr-sr-x 2 mlennert privileg 4096 Nov 6 18:22 CVS
> > -rw-r--r-- 1 mlennert privileg 63 Jul 13 14:59 README
> > -rw-r--r-- 1 root privileg 1986 Nov 13 11:46 head
> > -rw-r--r-- 1 mlennert privileg 2080 Nov 6 18:22 head.in
> > drwxr-sr-x 3 mlennert privileg 4096 Oct 24 19:09 os_specific
> > grep head Makefile:
> > VERSION= `cat src/CMD/VERSION | head -1`
> > NAME_VER= `cat src/CMD/VERSION | head -1 | sed 's/\..*//'`
> > CUTLINE= `grep -n '1999-12-29 16:12' ChangeLog |cut -d':' -f1 |
> > head -1`
> > # directories, head file, configure files, and Makefile - good
> > ${SHELL} -c "rm -f src/CMD/head/head 2>/dev/null ;
> > true"
> > head -${CUTLINE} ChangeLog > ChangeLog.cut
> I believe the problem is that the configure command is using its cache.
> Try the following
> make distclean
> ./configure
> make install
> Hope this helps.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
