[GRASSLIST:1113] Re: (no subject)
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Nov 13 06:42:43 EST 2000
mlennert at club.worldonline.be wrote:
> 'make distclean' doesn't seem to clean the cache. So I tried 'make
> veryclean'
> which does seem to clean the cache, but the problem is still the
> same...
Ooops you are right it should be veryclean, sorry. However I think you
don't have an up to date Makefile.in file. Check if the following is in
your Makefile.in (the wrapped lines are just a single line):
pre-install:
        test -d ${PREFIX} || ${INSTALL_DATA_DIR} ${PREFIX}
        test -d src/CMD/next_step || mkdir -p src/CMD/next_step
        test ! -f src/CMD/head/head || mv src/CMD/head/head
src/CMD/head/head.${ARCH}
        ${MAKE_GMAKE_ENV} ${MAKE_POST_ENV} ${SHELL}
src/CMD/generic/CREATE_GMAKE.sh ${ARCH}
        ${SHELL} ${IS64BIT} ${ARCH}
        @ echo "Now proceed with make install"
If the pre-install target does not appear as above then do a
cvs update Makefile.in
make veryclean
./configure
make install
I'm here for a few more minutes so if you still have problems.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
