[GRASSLIST:1121] Re: compiling individual modules
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Nov 13 12:12:10 EST 2000
Ok, I'll play the guinea pig ;-)
Sorry for the Quit button question. I just never have had to resize that
window, so I didn't even think of that option.
Moritz
> On Mon, Nov 13, 2000 at 04:28:58PM +0100, mlennert at club.worldonline.be wrote:
> > Hi,
> > after compiling GRASS-cvs successfully, I want to compile ps.map with the
> > -fwriteable-strings option. But how (or where) do I delete the ps.map object
> > files ?
> Hi Moritz,
> you change to
> cd src/ps.map/
> then
> find . -name 'OBJ*' -exec /bin/rm -rf {} \;
> This removes all the object files. After changing above option in
> src/CMD/head/head.$ARCH
> (replace ARCH with platform)
> you go back to
> cd src/ps.map/
> Then compile again
> gmake5
> Then ps.map should be o.k. We are working on this issue to get rid
> of this annoying compile problem.
> However: If you want to help us, please keep ps.map as-it-is
> and report the error *if* there. Maybe above procedure is not required
> any more. We need a tester, and it would be nice if you could first
> try the ps.map as it is.
> Thanks
>  Markus
> Dipl.-Geogr. Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
