[GRASSLIST:1134] Re: global data set
Markus Neteler
neteler at geog.uni-hannover.de
Wed Nov 15 12:05:00 EST 2000
Hi Seppo,
On Wed, Nov 15, 2000 at 01:38:46PM +0200, Seppo kaitala wrote:
> Dear all
> I have tried to get global dataset
> (http://www.geog.uni-hannover.de/grass/data.html)
> working under GRASS5.08b (and 4.3 as well)
> When I run v.support, I'll get the error message
> V.SUPPORT:
> Converting coastlines from 3.0 to 4.0
> Selected information from vector header
> Organization: CERL
> Map Name: Coastlines
> Source Date:
> Orig. Scale: -1067646976
> No snapping will be done
> Reading Vector file.
> OUT OF MEMORY!
> OUT OF MEMORY!
> Read_line: Out of Memory
> Could not build support (dig_plus) file.
> ERROR(v.support): Could not build vector file: 'coastlines'
> Anyhow, I think it is an other problem than memory
that's right (and known problem). Unfortunately the
"global" dataset in in dig3 format (very old). We need
a *volunteer* running either GRASS 4.1 or (better) GRASS 4.0.
Is anybody out there having this old GRASS version still running?
Then this person could download the "global dataset" from
open a GRASS monitor and load the map "coastlines" into v.digit.
Please enter a reasonable scale then etc. and leave v.digit.
Then please run v.support on the file and tell us about success :-)
All this in 4.0 or 4.1...
Then we might get the updated package from you (location packaged with
tar into a .tar.gz file, I could assist then).
Thanks in advance
Markus
