[GRASSLIST:1189] Re: notation standardisation
Morten Hulden morten at ngb.se
Sun Nov 26 15:00:40 EST 2000
On Sun, 26 Nov 2000, seppo kaitala wrote:
> Would it be good if the notation would be same for the same kind of
> consepts.
> For instance in commands
> v.proj map=name [out=name] inloc=name [dbase=name] [set=name]
> r.proj input=name location=name [output=name] [mapset=name][dbase=name]
> [method=name] [res=value]
The case r.proj/v.proj should be easy to fix, but which one is
preferrable? Also, s.proj's syntax is similar to r.proj's. But I think I
at least would prefer v.proj's shorter. Others?
MHu
