[GRASSLIST:1197] r.proj, v.proj, s.proj: parameter consistency fixed
Markus Neteler
neteler at geog.uni-hannover.de
Mon Nov 27 05:52:59 EST 2000
Hi all,
the parameter consistency is fixed now:
r.proj help
Description:
re-project a raster map from one location to the current location
Usage:
r.proj input=name location=name [mapset=name] [dbase=name]
[output=name] [method=name] [resolution=value]
Parameters:
input input raster map
location location of input map
mapset mapset of input map
dbase path to GRASS database of input location
output output raster map
method interpolation method to use
options: nearest,bilinear,cubic
default: nearest
resolution resolution of output map
v.proj help
Usage:
v.proj input=name location=name [dbase=name] [mapset=name]
[output=name]
Parameters:
input input vector map
location location containing input vector map
mapset mapset containing input vector map
output output vector map
s.proj help
Description:
Allows the user to re-project a sites file from one location to the current
location.
Usage:
s.proj input=name location=name [dbase=name] [mapset=name]
[output=name]
Parameters:
input input sites list
location location of input sites list
mapset mapset of input sites list
output output sites list
The documentation is changed accordingly.
Please note: You don't have to specify the *full* parameter(s),
just the first letter(s) are enough to make GRASS guess which parameter is
used. Example:
r.proj i=dgm1km l=europa ma=europa me=cubic
is sufficient to distinguish MEthods and MApset.
You may note that we are currently adding more information to "help"
parameter: A new "Description" field is there to explain the purpose of
the module.
Kind regards
Markus Neteler
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
