[GRASSLIST:1198] Re: [GRASS5] Re: notation standardisation
Markus Neteler neteler at geog.uni-hannover.de
Mon Nov 27 06:35:30 EST 2000
On Sun, Nov 26, 2000 at 11:12:37PM -0800, David Finlayson wrote:
> As a user issue, I like the way some command fields
> can be shortened in the fashion of r.watershed. Saves
> some typing at the command line...I would rather
> things be consistent rather than short however.
Hi David,
you don't have to specify full paramters. The minimum to
distinguish two similar parameters is sufficient.
Cheers
 Markus
