dxf import
Philippe JAOUEN pjaouen at DIAL.OLEANE.COM
Fri Oct 13 02:34:49 EDT 2000
"Eric G . Miller" a écrit :
> I didn't see a 'PERMANENT' directory (or any others indicating a
> mapset).  What mapset are you in?  Anyway, 'g.list vect' should tell you
> all of the vectors in the current mapset.
there is a PERMANENT directory with WIND
proj:       0
zone:       0
north:      5000
south:      0
east:       5000
west:       0
cols:       5000
rows:       5000
e-w resol:  1
n-s resol:  1
The beginning of my dxf file is:
  0
SECTION
  2
HEADER
999
$PLMAP
  9
$LIMMIN
 10
-1743.900
 20
1777.900
  9
$LIMMAX
 10
2293.300
 20
-3059.600
  0
ENDSEC
It seems there are positive and negative decimal coordinates
Salutations Philippe JAOUEN
Ferme du Ponctey :               http://worldserver2.oleane.com/ponctey
cidre fermier du Pays de La Risle, Pommeau de Normandie et Calvados AOC
