lines and areas
Stefan.Neumann at agrar.uni-giessen.de Stefan.Neumann at agrar.uni-giessen.de
Thu Oct 19 12:21:19 EDT 2000
Hi Grass,
is there a way to convert lines to areas ? I create lots of contour-lines with r.contour and I would like to make statistics (r.report type=area) on the areas surrounded by the contour-lines. This doesn't work though, because r.contour only creates lines, not areas.
Also I would like to create a map where the areas are filled with a color according to their attribute (with v.to.rast). This also only seems to work with areas.
TIA, Stefan
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20001019/e4a8bf52/attachment.html
