[GRASSLIST:1069] Re: 2 probs with lat long raster
Morten Hulden
morten at ngb.se
Sun Oct 29 05:24:22 EST 2000
On Fri, 27 Oct 2000, David Finlayson wrote:
> >From the lambert location, I run r.proj on the precip
> data in the geographic location. I get an error of
> bad coordinates related to the pole at 90N. I then
> made a new dataset that goes only to 89:30N and this
> appears to project, but when I view the projected
> result, only the eastern side of the central meridian
> (of the lambert projection) has been translated, the
> western half is completely missing. What went wrong?
You could try r.proj.new from the GRASS CVS repository (and probably
included in next GRASS release). It fixes most of the problems with
r.proj, which can only handle cylindical projections reliably.
regards
Morten Hulden
