r.in.gdal in GRASS5
Tom Poindexter
tpoindex at nyx.net
Wed Sep 27 10:17:09 EDT 2000
On Tue, Sep 26, 2000 at 05:38:36PM -0500, Frank Warmerdam wrote:
> The r.in.gdal command also takes a slightly new tack to projections. It
> reads the projection of the source dataset, and reports a fatal error if it
> does not match the current location (this check can be disabled with the -o
> flag). However, instead of the user having to manually define a new location
> and carefully setup the projection parameters, and bounds, it is possible to
> just rerun r.in.gdal, with the "location" parameter set to the name of the
> new location you would like to create. r.in.gdal will create the location
> and default the projection and extents based on the dataset.
This is a cool feature Frank, thanks! I'd like to see more of GRASS deal
with conflicting projections this way.
Tom Poindexter
tpoindex at nyx.net
http://www.nyx.net/~tpoindex/
