[GRASSLIST:1705] Re: GRASS on clusters
Markus Neteler
neteler at geog.uni-hannover.de
Thu Apr 5 10:26:04 EDT 2001
On Thu, Apr 05, 2001 at 09:03:26AM -0400, Lars Bromley wrote:
> Looks like I may have missed an important detail out there: GRASS would need to
> be recompiled in parallelized form, and this requires an expensive compiler or
> some heavy programming? Darn details and their devils...
> I was hoping that Beowulf would analyze the processes and distribute the
> computing tasks, am I misunderstanding how such software works?
> Thanks for your time,
Hi Lars,
I am not a specialist... As far as I know it's not sufficient to simply
use a parallelized compiler if code is written linear. I am quite sure
that algorithms need to be modified. We would need someone to search for
time consuming functions in GRASS code and modify those.
Perhaps you know more than me!
Just guessing,
Markus
PS: From the beowulf FAQ (www.beowulf.org):
"3. Can I take my software and run it on a Beowulf and have it go faster?
[1999-05-13]
Maybe, if you put some work into it. You need to split it into
parallel tasks that communicate using MPI or PVM or network sockets or
SysV IPC. Then you need to recompile it.
Or, as Greg Lindahl points out, if you just want to run the same
program a few thousand times with different input files, a shell script
will suffice.
As Christopher Bohn points out, even multi-threaded software won't
automatically get a speedup; multi-threaded software assumes
shared-memory. There are some distributed shared memory packages under
development (DIPC, Mosix, ...), but the memory access patterns in
software written for an SMP machine could potentially result in a
*loss* of performance on a DSM machine."
> Markus Neteler wrote:
> > On Wed, Apr 04, 2001 at 07:01:50PM -0700, Rich Shepard wrote:
> > > On Wed, 4 Apr 2001, Lars Bromley wrote:
> > > > I'd like to reopen Dr. Rich Shepard's year old message (see below) to this
> > > > list, regarding using GRASS with a cluster. I have a big project coming
> > > > up and am hoping to set up a cluster to help speed up the workload. Have
> > > > any of you experimented further with GRASS and clusters? Messages to the
> > > > listserv indicate that it is indeed possible, but I didn't see if anyone
> > > > had actually tried it. If anyone has, would they mind giving me a clue as
> > > > to how it might turn out? Does it speed things up, or is it more hassle
> > > > than its worth? I am using linux as my OS and will be using Beowulf as my
> > > > clustering software, and have six pentiums to start with.
> > > Lars,
> > > Some day, I'd like to be able to afford the port. The parallelizing
> > > compiler is very expensive (at least on my budget), but it is do-able. Right
> > > now, I have higher priorities on my GRASS time, and I've not read anything
> > > from anyone else about putting together such a port.
> > > There would be a large time investment, too, to reorganize the code so it
> > > could be parallelized. Candidly, I've no clue what that would require.
> > > Rich
> > excuse me to indrude here... Just a hint:
> > GRASS 5 contains the "gmath" library which is a wrapper to LAPACK/BLAS.
> > LAPACK/BLAS itself is a sophisticated mathematical library which exists
> > in parallelized form (as far as I know). See:
> > http://www.netlib.org/lapack/
> > Like that cpu-intensive parts in GRASS code could be rewritten to utilize
> > the "gmath" lib (src/libes/gmath/).
> > Maybe that's a starting point?
> > Regards
> > Markus Neteler
> > PS: Some "gmath" details can be found in the "GRASS 5 programmer's manual":
> > http://www.geog.uni-hannover.de/grass/grassdevel.html#prog
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
