[GRASSLIST:1730] FW: EGM96
Dieter Lehmann lehmann at fh-nuertingen.de
Mon Apr 9 08:03:36 EDT 2001
Hello,
(this message might come twice, I get a returned mail because of an not
reachable DNS-Server).
I need some advice in the area of projections...
How to create a location with the following attributes:
Projection: UTM
Horizontal Datum: WGS84
Geoid Model: EGM96 (thats the problem)
Vertical Reference Mean Sea Level (MSL)
It seems, that GRASS have no idea about EGM96, is there another Geoid-name with
the simular specifications?
Is the way correct to import the data into an UTM location, create a
Gaus-Krüger location and import the data from the UTM-location with r.proj?
Thanks,
Dieter
Dieter Lehmann
University of applied Sciences
Schelmenwasen 4-8
D-72622 Nuertingen, Germany
Phone: +49 (0) 7022 404 Ext. 192 or Ext. 152
Fax: +49 (0) 7022 404 Ext. 166
Date: Sat, 06-Apr-01 12:00:00 +0000 (GMT)
Time: 15:28:25
--------------End of forwarded message-------------------------
Dieter Lehmann
Schelmenwasen 4-8
Date: Tue, 09-Apr-01 12:00:00 +0000 (GMT)
Time: 13:56:47
