[GRASSLIST:1756] r.drain
Dela Lovecraft dela at ukonline.co.uk
Sun Apr 22 10:45:11 EDT 2001
Hello All,
Fairly new to GRASS, so bear with me! Using Grass 4.3 on a Linux box,
and playing with the various tutorials I have found. I have a question
about r.drain, to which I can't find a satisfactory answer - perhaps
someone can help?
If I produce a raster layer with r.cost, I have a layer showing how much
it will cost to move away from a given point. Fine. I then use r.drain
to plot the path from another given point, and I get a path of least
effort/cost.
With the layer produced by r.drain, each cell along this path has a
given value. Here is my question:
Assume there are n cells used in the path, and therefore n categories in
the r.drain roduced layer. Do each of these values represent the cost of
moving from the neighbouring cell to this one, or is it a cumulative
total of the cost of moving through *all* cells to this one? Or put
another way, does the value for cell n, the last cell in the path,
represent the move from (n-1) to n, or does it represent (1 + 2 ... +
n-1 + n) ?
Hope that makes sense...?
Dela Lovecraft
