[GRASSLIST:2245] Re: r.resamp.rst and r.resample
    Rich Shepard
    rshepard at appl-ecosys.com
    Thu Aug  2 13:51:16 EDT 2001
On Thu, 2 Aug 2001, Rich Shepard wrote:
>   The reason this is important is that the area I need to map is covered by
> a 3x3 array of DEMs. Six of the nine are already 10 m cells with 0.1 m
> elevation resolution while the other three are the lower resolution data.
  Here's some more information that may be pertinent.
  The three DEMs are all on the right column of the 3x3 array. I believe
that these are in the valley while the central column is mountainous and the
left column grades down from the hills.
Thanks,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
