[GRASSLIST:2246] Questions about regions
Rich Shepard rshepard at appl-ecosys.com
Thu Aug 2 16:47:05 EDT 2001
  I have a location named 'nevada' in which the DEFAULT_WIND, WIND,
PROJ_INFO and PROJ_UNITS files are in a directory (mapset) called
PERMANENT/. The bounds of the window and default window are the bounds of
the state. My project area is a small region within this location, and
that's in the mapset coeur/, with its own WIND value.
  I've imported DEMs using r.in.gdal. But, the three I've imported today
using the syntax:
r.in.gdal -o input=<sourcename> output=<newname>
show up (after cleaning with sed) as little rectangles in a large, white
rectangle.
  I want to concatenate these (eventually, all 9 DEMs), but they all have
the same region: the large, white background.
  My questions are: 1) what did I do wrong during importing so that only the
region covered by the DEM shows up (and I can view them all simultaneouly),
2) how can I determine the bounds just of the fraction that I want from each
map, and 3) how do I fix this and learn not to do it again?
Thanks,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
