[GRASSLIST:2257] r.patch -- problem solved
Rich Shepard
rshepard at appl-ecosys.com
Fri Aug 3 12:21:24 EDT 2001
Belay my previous post. The problem was caused by the color table for the
combined map, the reassignment of colors in the resultant map, and the
color of the lower elevations being the same as the background.
Using r.colors fixed this.
While on this topic of colors, how do I set GRASS-5 to take advantage of
the 16M colors my system supports? Even when I change the DEM map to use the
'wave' color table, it doesn't provide a wide enough range of color values
to show the topography well.
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Making environmentally-responsible mining happen.
