[GRASSLIST:2266] Display problem of floating point raster data
    Christian Georges
    christian.georges at uibk.ac.at
    Sat Aug  4 09:14:22 EDT 2001
Hello,
I'm running GRASS5 compiled from the CVS sources (24.07.) quite
smoothly on different PC's using different linux distributions (Redhat,
SuSE, 'LinuxFromScratch').
On one PC I experience a display problem (on the others I use the
same data, but have no display problems):
I can't display floating point raster data, whereas integer raster data show up with no problems.
The compilation of GRASS didn't give me any error, so I don't assume
that its really a GRASS problem, but more some kind of configuration
difficulties.
The floating point data are calulated by r.mapcalc on that machine, I can calculate r.support, stats and so on, thus the data seem to be ok.
seem to be ok.
Specs:
I start the display as usual: "d.mon start=x0" and get
"using default visual which is TrueColor
ncolors: 16777216"
Xserver configuration:
XFREE 3.3.6 11.0
24 bit
Windowmanager: KDE2
Distribution:
SuSE 7.1
(Hardware: Matrox Millenium II, Compaq Pentium 200MMX)
Should I run the server on 16 instead of 24 bit?
Any suggestions?
Thanks in advance,
Christian
