[GRASSLIST:2276] Re: Display problem of floating point raster data
Christian Georges
christian.georges at uibk.ac.at
Sun Aug 5 04:44:26 EDT 2001
Hi Glynn
oops, display is actually configured to run on 32 bits:
(from XF86Config:)
Section "Screen"
Driver "SVGA"
Device "Primary-Card"
Monitor "Primary-Monitor"
DefaultColorDepth 32
SubSection "Display"
Depth 32
Modes "1280x1024"
EndSubSection
Is this the reason for my problem?
> Do you get any errors?
No error output message.
CPU usage is at 100%, MEM and swap is filled up until the xserver dies.
I can stop d.mon command using STRG-C in GRASS xterm,
afterwards GRASS ist still stable!
> Is anything being drawn? (if you get a black window, use e.g. "d.erase
> red" first, so that you can distinguish between nothing being drawn
> and everything being drawn in black).
Nothing, it happens the same as described above.
> What output do you get from xdpyinfo?
xdpyinfo reports the server running on 24 bits depth (see below).
(I'm not experienced with xdpyinfo:
is it now actually running in 32 or 24 bits?
What is bitmap unit 32?
I assume 24 bits depth is the physical depth as produced by (or sent to) the monitor)
name of display: :0.0
version number: 11.0
vendor string: The XFree86 Project, Inc
vendor release number: 3360
maximum request size: 4194300 bytes
motion buffer size: 256
bitmap unit, bit order, padding: 32, LSBFirst, 32
image byte order: LSBFirst
number of supported pixmap formats: 2
depth 1, bits_per_pixel 1, scanline_pad 32
depth 24, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 255
focus: window 0x440000a, revert to PointerRoot
number of extensions: 19
BIG-REQUESTS
DOUBLE-BUFFER
DPMS
LBX
MIT-SCREEN-SAVER
MIT-SHM
MIT-SUNDRY-NONSTANDARD
RECORD
SECURITY
SHAPE
SYNC
XC-APPGROUP
XC-MISC
XFree86-DGA
XFree86-Misc
XFree86-VidModeExtension
XInputExtension
XKEYBOARD
XTEST
default screen number: 0
number of screens: 1
screen #0:
dimensions: 1280x1024 pixels (433x347 millimeters)
resolution: 75x75 dots per inch
depths (1): 24
root window id: 0x26
depth of root window: 24 planes
number of colormaps: minimum 1, maximum 1
default colormap: 0x23
default number of colormap cells: 256
preallocated pixels: black 0, white 16777215
options: backing-store YES, save-unders YES
largest cursor: 64x64
current input event mask: 0xf84033
KeyPressMask KeyReleaseMask EnterWindowMask
LeaveWindowMask KeymapStateMask SubstructureNotifyMask
SubstructureRedirectMask FocusChangeMask PropertyChangeMask
ColormapChangeMask
number of visuals: 1
default visual id: 0x22
visual:
visual id: 0x22
class: TrueColor
depth: 24 planes
available colormap entries: 256 per subfield
red, green, blue masks: 0xff0000, 0xff00, 0xff
significant bits in color specification: 8 bits
> Does d.colortable produce sensible output?
No, as above
I assume I have to change the Xserver configuration to 24 bits.
Anyway, Glynn thanks for helping!
Christian
