[GRASSLIST:2335] More Help
Kevin Slover
kjslover at nhc.noaa.gov
Thu Aug 9 14:34:00 EDT 2001
Well, I took Rich Shepards advice in using s.surf.idw...took way to much
time for what I am doing right now, so I was going to let it run
overnight. Instead I tried the s.surf.rst, just to try different
methods. Though I would have some luck with that one, but I kept
getting 2 error messages,
1. Concentration of points to high, try increasing dmin.
2. File size limit exceeded (core dumped).
So, one error leads to the other, I decreased dmin until it was at .1
(being that .5 of course is default) and it gives me the core dump. So,
I try .15 and I get the 1st one. I admit, the file size is large (using
an x,y,z format for 30m spaced Lidar Data for half of a county...it may
not be the proper way to get the raster, I am aware of this, I am trying
to learn why the errors...what is the file size dependent on?? Thanks
in advance, again
Kevin Slover, Meteorologist/Oceanographer
Tropical Prediction Center/National Hurricane Center
11691 SW 17th Street Miami FL 33165
Work: (305) 229-4456 Fax : (305) 553-1264
e-mail: kjslover at nhc.noaa.gov kevin.slover at noaa.gov
Web address: http://www.nhc.noaa.gov
