[GRASSLIST:2718] Re: Projections
Eric G. Miller egm2 at jps.net
Sat Dec 1 15:08:24 EST 2001
On Sat, 1 Dec 2001 16:38:58 +0000, Glynn Clements <glynn.clements at virgin.net> wrote:
[snip]
> > 2) is there a way so that a single user  can open two session of grass
> > and read data in two different locations?
> GRASS contains code to prevent a user from having multiple concurrent
> sessions. This could be disabled, but I'm not sure what the
> consequences would be; presumably this mechanism is there for a reason
> (although it might only be necessary to prevent concurrent access to a
> given mapset).
I think the single session per user limitation is due to the way grass
manages the session variables via ~/.grassrc5.
Eric G. Miller <egm2 at jps.net>
