[GRASSLIST:2739] Re: compiling grass and gd includes
Glynn Clements
glynn.clements at virgin.net
Wed Dec 5 14:43:45 EST 2001
cmbarton wrote:
> Thanks very much for the help. I will do this if needed. However, I have
> the PNG library, but don't know what it does for GRASS.
The PNG library is necessary for r.in.png, r.out.png, and the PNG
driver.
> What does GD do
GD provides a typical set of drawing commands (lines, polygons,
rasters, text) which draw into a PNG image.
> and what do I lose if I disable it?
The PNG driver; this allows you to do "d.mon start=PNG", to create PNG
images using GRASS display commands.
> Also, I do have GDAL installed, but GRASS doesn't want to build to it. I
> have included the --with-libs and --with-includes switchs to point to
> my lib and include directories. I have been using GDAL in the
> precompiled binary (for MacOSX) and want to continue to do so.
By default, r.in.gdal isn't linked against libgdal. It loads libgdal
at run time using dlopen(). I don't know whether this works on MacOSX.
You can force libgdal to be linked at compile time using configure's
"--with-gdal" switch. If an argument is specified, it is the path to
the "gdal-config" script. Otherwise gdal-config needs to be in your
path (configure uses gdal-config to obtain the necessary compiler and
linker switches).
Glynn Clements <glynn.clements at virgin.net>
