[GRASSLIST:2785] Re: Error in startup script
Eric G. Miller
egm2 at jps.net
Sun Dec 16 05:21:24 EST 2001
On Sun, 16 Dec 2001 08:55:34 +0100 (MET), bouffy <bouffy at free.fr> wrote:
> Hi,
> I've got a problem when I run the tcltkgrass command.
> The following message appears :
> Error in startup script: unmatched open brace in list
> while executing
> "llenght $line"
> invoked from within
> "if ![catch {open ~/.tcltkgrass r} stream] {
> while {[gets $stream line] >= 0} {
> if {[llenght $line] != 2 || \
> [set i [scan [lin..."
> (file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1840)
> invoked from within
> "source $env(TCLTKGRASSBASE)/main/gui.tcl"
> (file "/usr/local/grass5/bin/tcltkgrass" line 17)
Looks like somehow you got a typo in there. "llenght" should be "llength". I
couldn't find the typo in my sources...
Eric G. Miller <egm2 at jps.net>
