[GRASSLIST:2800] Re: Error in startup script
Glynn Clements
glynn.clements at virgin.net
Tue Dec 18 13:03:30 EST 2001
bouffy wrote:
> I've got a problem when I run the tcltkgrass command.
> The following message appears :
> Error in startup script: unmatched open brace in list
> while executing
> "llenght $line"
> invoked from within
> "if ![catch {open ~/.tcltkgrass r} stream] {
> while {[gets $stream line] >= 0} {
> if {[llenght $line] != 2 || \
> [set i [scan [lin..."
> (file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1840)
> invoked from within
> "source $env(TCLTKGRASSBASE)/main/gui.tcl"
> (file "/usr/local/grass5/bin/tcltkgrass" line 17)
> Is it a problem with the environment variables ?
I doubt it.
The error message implies that $line (a line from the ~/.tcltkgrass
file) contains an unmatched open brace. This suggests that the code
which writes ~/.tcltkgrass isn't doing it correctly.
Can you post your ~/.tcltkgrass file? That would provide some clues as
to the location of the error.
In the meantime, deleting or renaming your ~/.tcltkgrass file will
allow you to start tcltkgrass, although without any saved
configuration options.
Glynn Clements <glynn.clements at virgin.net>
