[GRASSLIST:2824] RE: Compilation problem using cygwin
Kidd, James P.
james.kidd at Covance.Com
Thu Dec 27 06:48:20 EST 2001
Glynn:
Thanks for the advice.
Apparently, the 'cannot create executables' messages is fairly common with
cygwin installs with incomplete development systems. I downloaded
everything that cygwin included on its distribution. I ended up wiping
cygwin clean and re-installing cygwin binaries, xfree86, and the grass5
source. The compile actually started this time, but I suspect that other
messages will appear in the log.
James Kidd
SAS Liaison Programmer
Covance Central Laboratory Services
8211 SciCor Dr
Indianapolis, Indiana 46214
james.kidd at covance.com
1-317-273-4914
-----Original Message-----
From: Glynn Clements [mailto:glynn.clements at virgin.net]
Sent: Wednesday, December 26, 2001 5:35 PM
To: Kidd, James P.
Cc: GRASSLIST at baylor.edu
Subject: Re: [GRASSLIST:2821] Compilation problem using cygwin
Kidd, James P. wrote:
> I tried compiling the latest Grass source in cygwin and got this error in
> the configure script:
> $ ./configure --enable-postgres=no \
> > --x-includes=/usr/X11R6/include \
> > --x-libraries=/usr/X11R6/lib \
> > --with-tcltk-libs=/usr/local/lib \
> > --with-tcltk-includes=/usr/local/include
> checking host system type... i686-pc-cygwin
> checking for gcc... gcc
> checking whether the C compiler (gcc ) works... no
> configure: error: installation or configuration problem: C compiler cannot
> create executables.
> Any ideas where I need to start?
Look in the "config.log" file. This contains all of the commands which
"configure" executes, along with their output, including any error
messages.
Glynn Clements <glynn.clements at virgin.net>
Confidentiality Notice: This e-mail transmission
may contain confidential or legally privileged
information that is intended only for the individual
or entity named in the e-mail address. If you are not
the intended recipient, you are hereby notified that
any disclosure, copying, distribution, or reliance
upon the contents of this e-mail is strictly prohibited.
If you have received this e-mail transmission in error,
please reply to the sender, so that we can arrange
for proper delivery, and then please delete the message
from your inbox. Thank you.
