[GRASSLIST:2831] Re: r.cost
Eric G. Miller
egm2 at jps.net
Sat Dec 29 04:50:51 EST 2001
On Sat, 29 Dec 2001 01:56:45 -0500, "Alexander Smotritsky" <alex at compuroute.net> wrote:
> I'm using grass5.0.0pre2 with the r.cost module from the 12/28/01 snapshot
> in the CVS. When I run r.cost there is no longer a segmentation error but an
> End of map! message and the resulting map is blank as with r.cost from the
> 5.0.0pre2 build.
> I'm not an experienced grass user so I'd like to know if r.cost isn't
> working or am I just running it wrong?
It's possible r.cost still has some problems. I tried to fix the errors
that I saw, but I did not exhaustively analyze the program. Perhaps you
could both describe how you're invoking it and the nature of the data
you're using. I assume your region settings include the data extents???
Eric G. Miller <egm2 at jps.net>
