[GRASSLIST:2833] core dumps after i.rectify
grass at gevaerts.be
Sat Dec 29 12:34:33 EST 2001
I am using Grass 5.0pre2 on a linux system (debian unstable , kernel
2.4.16, gcc 2.95.4)
After importing an image with r.in.tiff and rectifying it with i.rectify
(after doing all intermediate steps), every tool I tried coredumps on the
resulting raster (d.rast,r.support,r.compress,nviz,...)
The backtrace is :
(gdb) bt
#0 0x400c3c3b in free () from /lib/libc.so.6
#1 0x400c3ac3 in free () from /lib/libc.so.6
#2 0x08050a9b in close_old (fd=6) at closecell.c:76
#3 0x080508d6 in G_close_cell (fd=6) at closecell.c:44
#4 0x0804a595 in cell_draw (name=0x809a8d8 "meren",
mapset=0x809aa28 "PERMANENT", colors=0xbffff8f8, overlay=0, invert=0,
data_type=0) at display.c:134
#5 0x0804a34d in display (name=0x809a8d8 "meren",
mapset=0x809aa28 "PERMANENT", overlay=0, bg=0x0, data_type=0,
invert=0)
at display.c:59
#6 0x08049ba1 in main (argc=2, argv=0xbffffb74) at main.c:110
#7 0x4006e65f in __libc_start_main () from /lib/libc.so.6
(for d.rast, the others are identical from G_close_cell up, except that
nviz crashes on line 75 in closecell.c)
line 75 is : free (FCB.row_ptr);
line 76 is : free (FCB.col_map);
FCB seems to be :
(gdb) print G__.fileinfo[fd]
$1 = {open_mode = 1, cellhd = {format = 0, compressed = 1, rows = 2680,
cols = 1558, proj = 3, zone = 0, ew_res = 0.0083333333333333367,
ns_res = 0.0083320377567371474, north = 1.9559478066666667,
south = -20.373913381388888, east = 36.412333333333336,
west = 23.428999999999998}, reclass = {name = '\000' <repeats 49
times>,
mapset = '\000' <repeats 49 times>, type = 0, num = 0, min = 0, max =
0,
table = 0x0}, statf = {node = 0x0, tlen = 0, N = 0, curp = 0,
null_data_count = 0, curoffset = 0}, range = {min = 0, max = 0,
first_time = 0}, fp_range = {min = 0, max = 0, first_time = 0},
compression_bits = 0, want_histogram = 0, reclass_flag = 0,
row_ptr = 0x8093850, col_map = 0x8096238, C1 = 1, C2 = 0.5, cur_row =2679,
null_cur_row = -1, cur_nbytes = 1, data = 0x8097a98 "", nbytes = 1,
map_type = 0, temp_name = 0x0, null_temp_name = 0x0, null_file_exists =
1,
name = 0x808da68 "meren", mapset = 0x808da78 "PERMANENT", io_error = 0,
xdrstream = {x_op = XDR_ENCODE, x_ops = 0x0, x_public = 0x0,
x_private = 0x0, x_base = 0x0, x_handy = 0}, NULL_ROWS = {
0x8093148 "HÍ\032 at HÍ\032@", 'ÿ' <repeats 184 times>, "È",
0x8093210 'ÿ' <repeats 192 times>, "\220\001",
0x80932d8 'ÿ' <repeats 192 times>, "X\002",
0x80933a0 'ÿ' <repeats 192 times>, " \003",
0x8093468 'ÿ' <repeats 192 times>, "è\003",
0x8093530 'ÿ' <repeats 192 times>, "°\004",
0x80935f8 'ÿ' <repeats 192 times>, "x\005",
null_work_buf = 0x8093788 'ÿ' <repeats 192 times>, "\b\a",
min_null_row = 2672, quant = {truncate_only = 0, round_only = 0,
defaultDRuleSet = 0, defaultCRuleSet = 0, infiniteLeftSet = 0,
infiniteRightSet = 0, cRangeSet = 0, maxNofRules = 0, nofRules = 0,
defaultDMin = 0, defaultDMax = 0, defaultCMin = 0, defaultCMax = 0,
infiniteDLeft = 0, infiniteDRight = 0, infiniteCLeft = 0,
infiniteCRight = 0, dMin = 0, dMax = 0, cMin = 0, cMax = 0, table =
0x0,
fp_lookup = {vals = 0x0, rules = 0x0, nalloc = 0, active = 0,
inf_dmin = 0, inf_dmax = 0, inf_min = 0, inf_max = 0}}}
Is this a known problem, or am I doing something wrong ?
Please ask if you need more info
Frank
HI! I'm a .signature virus! cp me into your .signature file to help me spread!
