[GRASSLIST:1421] Re: REPOST: d.vect cutting algorithm?
Johansen Per Henrik
per.henrik.johansen at norgit.no
Mon Feb 5 06:55:27 EST 2001
Both layers continue to the west (I am using the spearfish mapset and that
should be correct, or? You should also be able to reproduce this effect).
I also tried a little experiment and rezised the X display; this also seem
to cut the roads to the west! See http://www3.norgit.no/apnee/tcl2.png
I have no idea what is happening, but it seems to that d.area and d.vect
uses different cutting functions or are invoked with different coordinates.
I have tried to look in the source, and I see that d.vect has a plot2()
function that is missing from d.area. Might this have something to do with
my problem?
FYI: There is no more map data to the east, thats way it is not cut off, I
have tried this with some of my own mapsets and GRASS happily cuts to both
east and west, but never to the north and south.
FYI2: I am using Grass 5.0 beta 10
Per Henrik
Per Henrik Johansen
Norgit AS, http://www.norgit.no
-----Original Message-----
Sent: Saturday, February 03, 2001 3:25 AM
To: 'GRASSLIST at baylor.edu'
Subject: [GRASSLIST:1417] Re: REPOST: d.vect cutting algorithm?
On Fri, Feb 02, 2001 at 10:00:40AM +0100, Johansen Per Henrik wrote:
> Grasslist,
> I tried to send this request some days ago but it seems that it never
> reached the list. I apologize if this request should reach you twice.
> I am having some difficulties when trying to join several vector layers
into
> a raster file; GRASS will not draw vectors (polygons work fine) at the n
> leftmost and/or n rightmost pixels of the image.
> I use the d.area command to draw polygons and d.vect to draw lines. d.vect
> seems to cut off lines that stretches beyond the edge of the image. Is
this
> a known problem or am I missing out on something?
> An image that illustrate my point (roads and streams near the left edge is
> cut off) might be found at:
> http://www3.norgit.no/apnee/D_cell.png
> It is generated with the following GRASS commands:
> g.region n=4928226 s=4911624 e=612344 w=593807
> d.mon start=CELL
> d.mon select=CELL
> d.area map=fields fillcolor=green linecolor=black
> d.vect map=roads color=red
> d.vect map=streams color=blue
> d.mon stop=CELL
> g.region raster=D_cell
> r.out.png D_cell
> I have also tried to use tcl/tk interface to generate the same image/map.
> Here everything seems to work fine, see
http://www3.norgit.no/apnee/tcl.png
> Anyone know what I am experiencing here?
You sure your vector layers (other than fields) continue to the west?
The D_cell version obviously contains more real estate on the west side
than the X monitor version. The X monitor version draws the roads about
to where they "cut off" in the D_cell version. So maybe the CELL driver
is drawing more than you want?
Eric G. Miller <egm2 at jps.net>
