[GRASSLIST:1458] ps.map scale command
    mlennert at club.worldonline.be
    Wed Feb 14 11:54:39 EST 2001
Radim,
In the ps.map scale command, I can set the scale below a certain limit, but
not above. In my example:
Exporting a world map through ps.map without setting the scale, I get:
PS-PAINT: PostScript painter "a4" selected.
PS-PAINT: scale set to 1 : 177342342
in the ps.map io-window.
I can set any scale that is lower than that, as for example 1:200000000, but
none that are higher. Is this a feature, and the program automatically limits
to the largest scale that can fit on the given paper, or is this a bug ?
Secondly, is it possible to put a bar scale, not a numerical scale on the map ?
Moritz
